Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Changing X- and Y-axis range in the data visualizer › Reply To: Changing X- and Y-axis range in the data visualizer
October 25, 2021 at 10:16 pm
Guilin Sun
Could you please follow up the previous procedures I suggested and check where leads this issue?
Please narrow down the questions for this post. I believe that the original question has been resolved for periodic case.
For your new FDTD monitor profile, I am not sure the simulation condition so I cannot comment. If you still use the plane wave plus periodic BCs the results are incorrect as the antennas have different field profiles. Please write a new post with more details, if you still have questions. The ALF policy is for one question one answer.
