Ansys Learning Forum Forums Discuss Simulation Fluids Pressure Drop of Water Laminar Flow in a Pipe is not Correct!! Reply To: Pressure Drop of Water Laminar Flow in a Pipe is not Correct!!
hhayati
Yes, I did enable gravity.
You mean Fluent does not account for the vertical distance between two points if it wants to report static pressure? If so, does it do this only for laminar flow or for both laminar and turbulent flow?
