Ansys Learning Forum Forums Discuss Simulation Electronics Voltage Source – HFSS Reply To: Voltage Source – HFSS
ha_nguyen3
My operating conditions are 42V and 200kHz. I want to study electrodynamics, rather than electrostatics. For clarification, there are an air gap and other 7 layers of materials with high dielectric constants (e>100) between two parallel plates.
Is there a way to add a voltage on one plate and set GND to the other plate without defining the E-field direction first?
I tried lumped port, but different locations of the port give me different field strengths across the model.
Thank you.
