Ansys Learning Forum Forums Installation and Licensing Ansys Products Running Ansys Fluent in a HPC Cluster with LSF scheduler, Intel MPI, and Docker without SSH Reply To: Running Ansys Fluent in a HPC Cluster with LSF scheduler, Intel MPI, and Docker without SSH
sleong
Hi mmadore Thank you very much mmadore for the solution, I can submit to our cluster now. But, I got the error "Received signal SIGSEGV.". I can run the test job to finish occasionally with 2 nodes but most of the time I still get the error "Received signal SIGSEGV.". For more than 2 nodes jobs, It always fail with that error. How can I fix the problem?
Building...
mesh
auto partitioning mesh by Metis (fast) distributing mesh
parts.................................................. ==============================================================================
Node 47: Process 24: Received signal SIGSEGV.
Node 45: Process 22: Received signal SIGSEGV.
Node 44: Process 21: Received signal SIGSEGV.
Node 42: Process 19: Received signal SIGSEGV.
*** Error in `/export/ansys21/v211/fluent/fluent21.1.0/lnamd64/3ddp_node/fluent_mpi.21.1.0': double free or corruption (fasttop): 0x0000000007c26520 ***
*** Error in `/export/ansys21/v211/fluent/fluent21.1.0/lnamd64/3ddp_node/fluent_mpi.21.1.0': double free or corruption (fasttop): 0x000000000692a870 ***
*** Error in `/export/ansys21/v211/fluent/fluent21.1.0/lnamd64/3ddp_node/fluent_mpi.21.1.0': double free or corruption (fasttop): 0x000000000566beb0 ***
*** Error in `/export/ansys21/v211/fluent/fluent21.1.0/lnamd64/3ddp_node/fluent_mpi.21.1.0': double free or corruption (fasttop): 0x00000000057102b0 ***
*** Error in `/export/ansys21/v211/fluent/fluent21.1.0/lnamd64/3ddp_node/fluent_mpi.21.1.0': double free or corruption (fasttop): 0x00000000058c4740 ***
======= Backtrace: =========
/lib64/libc.so.6(+0x81299)[0x7fc52cba4299]
/lib64/libc.so.6(+0x81299)[0x7f95ced34299]
/lib64/libc.so.6(+0x81299)[0x7f2134f55299]
/export/ansys21/v211/fluent/fluent21.1.0/lnamd64/syslib/libstdc++.so.6(_ZNSsD1Ev+0x3e)[0x7f2139c6bede]
/lib64/libc.so.6(+0x81299)[0x7f3d58ee1299]
/export/ansys21/v211/fluent/fluent21.1.0/lnamd64/syslib/libstdc++.so.6(_ZNSsD1Ev+0x3e)[0x7f3d5dbf7ede]
/lib64/libc.so.6(+0x81299)[0x7f1a1e11e299]
/export/ansys21/v211/fluent/lib/lnamd64/libansysfluidssettingsparsers.so(_ZN5ansys21GenericSettingsParserD2Ev+0x46)[0x7f1a2f8ebcd6]
/lib64/libc.so.6(__cxa_finalize+0x9a)[0x7f1a1e0d705a]
/lib64/libc.so.6(__cxa_finalize+0x9a)[0x7f2134f0e05a]
/export/ansys21/v211/fluent/lib/lnamd64/libansysfluidsproject.so(+0x37e43)[0x7f2146207e43]
======= Memory map: ========
/lib64/libc.so.6(__cxa_finalize+0x9a)[0x7f3d58e9a05a]
/export/ansys21/v211/fluent/lib/lnamd64/libansysfluidsproject.so(+0x37e43)[0x7f3d6a193e43]
/export/ansys21/v211/fluent/fluent21.1.0/lnamd64/syslib/libstdc++.so.6(_ZNSsD1Ev+0x3e)[0x7fc5318baede]
/lib64/libc.so.6(+0x39ce9)[0x7fc52cb5cce9]
/lib64/libc.so.6(+0x39d37)[0x7fc52cb5cd37]
/export/ansys21/v211/fluent/fluent21.1.0/multiport/lnamd64/mpi/shared/libmport.so(+0x87012)[0x7fc53c5b2012]
/export/ansys21/v211/fluent/fluent21.1.0/lnamd64/syslib/libstdc++.so.6(_ZNSsD1Ev+0x3e)[0x7f95d3a4aede]
/lib64/libc.so.6(__cxa_finalize+0x9a)[0x7f95ceced05a]
/export/ansys21/v211/fluent/fluent21.1.0/cortex/lnamd64/libExpr.so(+0xac0e3)[0x7f95df0d60e3]
/export/ansys21/v211/fluent/lib/lnamd64/libansysfluidsfactory.so(+0x5c63)[0x7f1a2fd94c63]
/export/ansys21/v211/fluent/fluent21.1.0/multiport/lnamd64/mpi/shared/libmport.so(+0x8712d)[0x7fc53c5b212d]
/export/ansys21/v211/fluent/fluent21.1.0/multiport/lnamd64/mpi/shared/libmport.so(+0x8f1a3)[0x7fc53c5ba1a3]
/lib64/libpthread.so.0(+0x7ea5)[0x7fc539664ea5]
/lib64/libc.so.6(clone+0x6d)[0x7fc52cc2196d]
*** Error in `/export/ansys21/v211/fluent/fluent21.1.0/lnamd64/3ddp_node/fluent_mpi.21.1.0': double free or corruption (fasttop): 0x0000000007d47910 ***
===============Message from the Cortex Process================================
Fatal error in one of the compute processes.
/lib64/libc.so.6(+0x81299)[0x7f24a88bf299]
/export/ansys21/v211/fluent/fluent21.1.0/lnamd64/syslib/libstdc++.so.6(_ZNSsD1Ev+0x3e)[0x7f24ad5d5ede]
/lib64/libc.so.6(__cxa_finalize+0x9a)[0x7f24a887805a]
/export/ansys21/v211/fluent/lib/lnamd64/libansysfluidsproject.so(+0x37e43)[0x7f24b9b71e43]
