Ansys Learning Forum Forums Discuss Simulation LS Dyna How to perform two step dynamic analysis in Ansys Mechanical Reply To: How to perform two step dynamic analysis in Ansys Mechanical
peteroznewman
How to fix the error.
Suppress both Frictionless Supports, You have Nodal Displacements to replace them.
The Displacement 3 on the bottom faces includes nodes used in the Fixed Joint to the bottom rail.
Create a Nodal Selection of nodes on the bottom rail that avoids the nodes used in the Fixed Joint.
