Ansys Learning Forum Forums Discuss Simulation Fluids Regarding consideration of saturation temperature as function of pressure in subcooled flow boiling Reply To: Regarding consideration of saturation temperature as function of pressure in subcooled flow boiling
sachintom1992
Sir I simulated low-pressure subcooled flow boiling of the water case. The radial vapor fraction trend is not at all followed in the case of saturation temperature as a function of local pressure. The vapor fraction considerably moves on to the core region here whereas in the experiment such a variation is not there.
The liquid properties are given as a function of temperature and vapor properties at Pressure outlet-based saturation temperature.
Latent heat is given as constant at pressure outlet-based Tsat.
Can we give latent heat variation with Tsat?
Regards Sachin
