Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Simulation setup for particle between two media. › Reply To: Simulation setup for particle between two media.
July 27, 2021 at 3:54 pm
Guilin Sun
Let me summarize your target to be simulated: random particles inside lossy medium, and use high NA to collect the scattering and reflection? is the scattering angular field-intensity distribution or the scattering cross section what you want? before any suggestions are given, I wish to know what exactly you want to get. You may also describe what quantity you get from experiment. Thank you!
