Ansys Learning Forum Forums Discuss Simulation Fluids Unable to report plot Reply To: Unable to report plot
Danielgkh
By setting, do you mean solver setting or WB setting? I changed my solver setting quite often, for example, urf and coupling method, otherwise, I never touch any setting for WB.
I just ran the simulation again and I feel like the problem lies with me interrupting the calculation and save the project halfway for my last 2 simulation. My latest simulation has no problem plotting all the data point when I ran the whole calculation to the end. This was the case for my fist simulation as well.
Usage of WB is not compulsory for me, I just feel like the workflow is smoother with WB. I can actually straight away import the geometry from SpaceClaim into Fluent Meshing then into Fluent Solution.
