Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Can somebody help for ekill script for block structure under compression inorder to see the failure? › Reply To: Can somebody help for ekill script for block structure under compression inorder to see the failure?
July 24, 2021 at 6:51 pm
peteroznewman
I suggest you run this model in Explicit Dynamics where you will see the failure. Erosion will remove elements during the solution based on a strain criterion (default) or on a material failure criterion if you have that in your material and you change the Erosion setting to On Material Failure.
