Ansys Learning Forum Forums Discuss Simulation General Mechanical how to create a crack on a 3D surface body in ANSYS workbench? Reply To: how to create a crack on a 3D surface body in ANSYS workbench?
elhamasadi
I want to draw
(1) an edge crack (length= 100 mm, gap=10 mm), in the middle of one of the edges
(2) a crack at the center (the same dimensions)
Provided that I need the geometry to remain as surface body, so that I can apply simply supports on four edges later on in mechanical environment
Thank you
