Ansys Learning Forum Forums Discuss Simulation Fluids Explicit VOF vs Implicit VOF for Laser Melting? Reply To: Explicit VOF vs Implicit VOF for Laser Melting?
Dubey92
Thanks for your suggestion. I have a doubt. The simulation shows "floating point exception" in the middle of the simulation. Then I make some change, usually in the Courant Number. Then I start the simulation from the same point and it gets completed. Does it affect the accuracy of the results?
