Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Create plot of DPM particle surface impacts › Reply To: Create plot of DPM particle surface impacts
July 22, 2021 at 9:23 am
The easiest way will be to (ab)use the accretion model. From there you'd need a UDF to add a particle strike into a wall User Defined Memory, that's not as easy but there may be an example in the documentation.
