Ansys Learning Forum Forums Discuss Simulation Fluids Gradient of temperature in momentum source term while using solidification/melting with VOF Reply To: Gradient of temperature in momentum source term while using solidification/melting with VOF
DrAmine
I won't comment that piece of code. As new user I will rather stick to the default workflow to get gradients and that is meant with keep memory from being freed
