Ansys Learning Forum Forums Discuss Simulation Electronics Illegal External Terminal – assigning current to a coil Reply To: Illegal External Terminal – assigning current to a coil
elramire
The errors under the magnetostatic are the same as the ones for Eddys current. I know the picture for Eddy states the solution setup, but even after assigning the solution setup I still get the same errors as the ones for Magnetostatic regarding the conduction path.
