Ansys Learning Forum Forums Discuss Simulation General Mechanical Distributed Moment Load Reply To: Distributed Moment Load
ErKo
Hi
There is not a command to do this (moment/unit length load) - most likely you need to loop over the nodes and apply a nodal moment with the moment needed at that point (done via the F command and using MX,MY moment labels - see F command for more details in our help manual).
Thank you
Erik
