Ansys Learning Forum Forums Discuss Simulation General Mechanical Adding something like UDF in Ansys Mechanical / Adding a source term Reply To: Adding something like UDF in Ansys Mechanical / Adding a source term
peteroznewman
I advised you to look into Fluent in another discussion /forum/discussion/comment/126208#Comment_126208 you replied to in the Structures category, and now I have found that has made the same recommendation in this discussion.
Fluent can do chemical reactions. Here is a page from the theory manual.
As I said in the other discussion, and as Ishan says in this discussion, try posting in the Fluids category, really.
