Ansys Learning Forum Forums Discuss Simulation Fluids 2-Way System Coupling with Fluent Mesh Interface? Reply To: 2-Way System Coupling with Fluent Mesh Interface?
Steve
Hi Henry The example model is included in the Course Materials which you can download from the Ansys Learning Hub. That should provide you enough information. Other than the Ansys Learning Hub, this topic isn't covered anywhere else.
Steve
