Ansys Learning Forum Forums Discuss Simulation Fluids Which solution method (scheme) should I select for multiphase flow (pumping gas to blow water out)? Reply To: Which solution method (scheme) should I select for multiphase flow (pumping gas to blow water out)?
Looks reasonable. How are the balances, and how sensible do the results look? Note, inflation tends to result in a fairly high aspect ratio which then causes problems, you may find you need to resolve near the wall and in the streamwise directions at much the same resolution.
