Ansys Learning Forum Forums Discuss Simulation General Mechanical Seeing a change in maximum moments when reversing the direction of a line body. Reply To: Seeing a change in maximum moments when reversing the direction of a line body.
Rameez_ul_Haq
,I re-checked but it is. Just a line body, with end points connected to each hole of a separate solid body. Nothing else. Should I regard this difference in the force between the two as a numerical error?
