How to get this volumetric flux (cc/s/cm2) for DPM simulation (3D) in Fluent?
    • kumar119
      I have been trying to get the type (attached figure) of plot/data in Fluent.
      Can someone help me on this regard?
      The plot is for volumetric flux (cc/s/cm2).
      Or one more figure, I have attached below (DPM volume flow rate):
      Have a look at the DPM Summary and .out files. The former may give you the graph directly, the latter will tell you where, when & how much parcel mass passes through the defined surface/boundary.
  • The topic ‘How to get this volumetric flux (cc/s/cm2) for DPM simulation (3D) in Fluent?’ is closed to new replies.
