same time step in a transient table for a transient boundary condition
    • mounaraha
      hello In fluent, for the transient table in a transient boundary condition of a wall temperature , should the time step be the same for example 0.01 or i can have 2 different time steps for the first three values of temperature for example 0.01 and for the other values 1 second ?
      thank you
    • Nikhil N
      You can independently define your time step size and it's variation with respect to time with the help of an expression. If your time step size is a function of time (actual time), you can simply write an expression as a function of time. If not, you can use 'If' function while writing an expression.
      To know more about Fluent Expressions Language, please refer to this section of the user's guide: Chapter 5: Fluent Expressions Language (ansys.com)
      If you are not able to access the above link, refer to this forum discussion: Using Help with links ÔÇö Ansys Learning Forum
      Nikhil
  • The topic ‘same time step in a transient table for a transient boundary condition’ is closed to new replies.
