May 25, 2022 at 8:50 pm
jsarlo
SubscriberThis is a general Ansys question. We run Ansys through Slurm on a RHEL 8 cluster. We are having problems with some of the older intel mpi version working properly with our combination of Slurm and RHEL 8. We have found the latest version of intel mpi seems to work properly.  Is there an environment variable or some option to Ansys to tell it to use an Intel MPI other than the 2018 version provided with Ansys 2022R1?
Jeff
May 26, 2022 at 1:30 pm
MangeshANSYS
Ansys Employeesee Using an alternative MPI version at https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v221/en/ans_dan/Hlp_G_ADVPARA_4.html
you can try setting I_MPI_ROOT and see if it helps use a different MPI version
May 26, 2022 at 2:14 pm
jsarlo
SubscriberThat used to work in older versions of Ansys, but it seems to be ignored in this version. The process that gets stuck is coming from the Ansys install
/share/apps/ansys-2022r1/v221/commonfiles/MPI/Intel/2018.3.222/linx64/bin/pmi_proxy --control-port compute-4-1.local:32815 --pmi-connect alltoall --pmi-aggregate -s 0 --rmk slurm --launcher slurm --demux poll --pgid 0 --enable-stdin 1 --retries 10 --control-code 914088375 --usize -2 --proxy-id -1
Jeff
May 31, 2022 at 12:03 pm
MangeshANSYS
May 31, 2022 at 12:17 pm
jsarlo
SubscriberAnsys ignores the I_MPI_ROOT variable.
May 31, 2022 at 7:00 pm
MangeshANSYS
Ansys Employeedid the command line flag for intel mpi version 2019 in the linked help page work for you ?
May 31, 2022 at 7:11 pm
jsarlo
SubscriberNo - version 2019 has the same issue as 2018. I have also tried the openmpi that comes with Ansys and I get different errors with it.
Viewing 6 reply threads
- The topic ‘Use our own Intel MPI installation and not the one from Ansys’ is closed to new replies.
1311
