May 23, 2022 at 12:15 pm
Amirr
SubscriberHello everyone I am using VOF model in Ansys FLUENT and going to calculate the droplet speed in every time step and monitor that.
I wrote this expression but it doesn't get a reasonable result, I wonder if somebody helps me about that
Average(IF(Volumefraction(phase='droplet')>0.99, Position.x, 0 [m]), ['fluid'], Weight='Mass')
Thank you in advance.
May 23, 2022 at 2:22 pm
Amine Ben Hadj Ali
Ansys EmployeeYour expression does not mass-weighed-average the speed but rather the position.
May 23, 2022 at 2:32 pm
Amirr
Subscriberthank you so much. so what is the correct version?
yes, here first I just want to know the x-location of droplet
then using the below one I am going to find the droplet velocity
Average(IF(Volumefraction(phase='droplet')>0.99, velocity.x, 0 [m]), ['fluid'], Weight='Mass')
but they are not worked -
May 23, 2022 at 4:08 pm
Amine Ben Hadj Ali
Ansys EmployeeUse report definition directly without any expressions.
Your formula looks okay so I cannot judge your results. What do you want to do?
May 23, 2022 at 4:56 pm
Amirr
SubscriberI need the droplet phase speed, location (x, y, separately), how can I get that and monitor them as the simulation runs?
May 23, 2022 at 7:19 pm
Amine Ben Hadj Ali
Ansys EmployeeCreate report definitions then allow for writing them into file. You can moreover monitor them during the run.
April 13, 2023 at 7:18 am
smukhopadhyay
SubscriberI would like to obtain the droplet velocity and move the mesh with average droplet velocity. Can this be done with expresssion or we need to write an udf?
Viewing 6 reply threads
- The topic ‘Writting an expression’ is closed to new replies.
- affinity not set
1487
