May 21, 2022 at 1:56 am
Oppen
SubscriberHello everyone. I´m working on a support structure which consists on several plates screwd to a base.
Each plate was modeled as a midsurface.
The contacts between the plates would be frictional.
Which would be the appropiate manner to realize the connection?
A) Should I create a beam connection between each pair of plates?
B) Should I use 1 beam connection selecting 1 plate as reference scope and 10 plates as mobile scope?
C) Should I use 1 beam connection selecting 5 plates as reference scope and 6 plates as a reference scope?
Any comment would be aprreciated.
Any suggestions , .
Thanks Oppen.
May 23, 2022 at 8:30 am
Ashish Khemka
Is there a gap between the plates and the screw? If yes then you can the approach indicated here:
Bolt Modeling Connections as Beam Elements | Ansys Courses
If there is contact between screw and plates then one simplification might be defining frictional contact (edge to edge) between bolt and plate.
Regards Ashish Khemka
- The topic ‘Correct Application of Beam Connections’ is closed to new replies.
1310
