TAGGED: bolt-pretension, bridge, cable-dynamics, peteroznewman, surface-tension
May 19, 2022 at 2:27 pm
omar30
SubscriberHello ,
I got a problem and have been trying to solve. Considering a cable (hanger) that has boundary conditions as pinned-pinned or fixed-fixed. I am trying to evaluate the stress in the beam element, as previously suggested to use bolt pretension which solved the tension issue. I got 2 questions and I hope to receive answers about them:
- Why applying bolt pretension force calculate accurate solution however force applied at supports gives wrong solution?(attached pictures 1,2 are for bolt pretension ,3,4 for force )
- If I am willing to apply a horizontal force component or moment at the lower part of cable. What form should I introduce the force/ moments? as a nodal force or?
I appreciate your support and hope to get a response
May 31, 2022 at 8:38 amAshish Khemka
You can fix one end and apply force/ moment at the other end.
Regards Ashish Khemka
Viewing 1 reply thread- The topic ‘Modelling a cable as beam element’ is closed to new replies.
6319
