May 16, 2022 at 2:29 pm
Luca_Patriarchi
SubscriberHi all,
I am tring to perform a hamronic response of a structure using, as dampers, four springs attached to the basement. The problem is that a message comes out writing
"The system is solved without damping. This may cause very large peak harmonic responses around natural frequencies due to resonance".
How may I fix it?
May 17, 2022 at 12:38 pmViewing 1 reply thread- The topic ‘How to perform harmonic response in Static Structural with dampers?’ is closed to new replies.
3492
1057
1051
965
942
