May 16, 2022 at 12:39 pm
allami
SubscriberHello everyone
Can anyone tell how fluent calculate the heat transfer coefficient for a surface ( which formula does it use)? as far as I know, h = total wall heat flux/( T_wall -T_ref). The reference temperature is the volume average of the fluid temperature, which is bulk temperature. Using this formula, the heat transfer coefficient will be different from the heat transfer coefficient defined in the fluent.
Best regards
May 16, 2022 at 2:05 pmKishan Konannavar
Ansys EmployeeHello
In a basic way, the Tref is provided by the user in the Reference Values task page.
Regards
Kishan
May 16, 2022 at 2:10 pmallami
SubscriberYes, I must define the Tref in Task Page. But the heat transfer coefficient ( h ) will be different if I calculated it according to above equation with a custom function.
May 16, 2022 at 2:58 pmRob
Forum ModeratorHave a look in https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v221/en/flu_ug/flu_ug_fvdefs.html there are several ways to calculate the HTC, or rather several options to take the temperature in the solver.
Viewing 3 reply threads- The topic ‘Heat transfer coefficient.’ is closed to new replies.
3597
1208
1092
1068
952
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
