TAGGED: ansys-aqwa, aqwa, hydrodynamic-diffraction, workbench
May 12, 2022 at 9:46 pm
aakashg57
SubscriberI am trying to model a spar-floater system in Ansys Aqwa and calculate the force on both spar and floater
I have 2 questions:
- How is the phase of the force defined?
- What does the direction "-180 degrees" - marked by a blue circle in the attachment mean?
Thanks a lot
The attachment can be accessed here too: https://imgur.com/a/6ptKQ1A
May 13, 2022 at 2:08 pmIngrid M
Ansys EmployeeHello In the Aqwa reference manual (section 1.2.3), you have the definition of the phase angle, how it calculated as well as the meaning of the sign of the phase for a given output parameter you are looking at.
By convention a positive phase angle indicates that the parameter max value is reached after the wave peak, i.e. the parameter lags behind the wave.
This observation takes place at a reference point (in Aqwa, this is the COG of the structure). The phase is defined so that the time difference between the wave reaching its peak and the parameter reaching its max value is equal to the wave period * phase / 360.
I hope this helps.
Kind regards Ingrid
May 19, 2022 at 10:10 pmaakashg57
SubscriberThank you for your answer. Could you also shed some light on my second question if possible?
2. What does the direction "-180 degrees" - marked by a blue circle in the attachment mean?
The attachment can be accessed at https://imgur.com/a/6ptKQ1A
Viewing 2 reply threads- The topic ‘How is Diffraction and Froude-Krylov force phase defined in Ansys Aqwa?’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- air flow in and out of computer case
- affinity not set
Top Contributors-
3997
1461
1287
1124
