Electronics
Electronics
Error : Point in mesh was not found !
    • guessoum.anis
      I am analyzing a specific motor using Maxwwell 2D Transient in AEDT 2021 R2, I set up the model manually, it's an IPM synchronous motor (see attached file). When I analyze it i keep getting this error :
      Maxwell2d solver, process solver2d error: Internal Solver Error: 'Point in mesh was not found! '. Please contact Ansys technical support.
      Any idea what might the problem be ?
      Anis
    • Navya Chode
      Can you try the following?
      Add a dummy band object between the band and stator airgap.
      Under in initial mesh setting, move the slider towards a more fine setting.
      IF this did not work, change the mesh Method to classic in the Initial mesh settings and check.
      Regards Navya
    • guessoum.anis
      The 2nd an 3rd solutions worked, thank you :)
      Have a nice day
      Anis
  • The topic ‘Error : Point in mesh was not found !’ is closed to new replies.
