May 9, 2022 at 6:15 pm
eduardo.delarocha
SubscriberDear all,
I am working on the development of an Earth-Air Heat Exchanger (EAHE) and I was wondering if the Sand-grain Roughness model could be used to simulate the thermal performance of corrugated pipe walls (of about 10 mm).
I tried to geometrically draw the corrugation but the model was very heavy when I launched the simulations.
Thank you very much in advance!
Best regards.
May 11, 2022 at 12:22 pmSVV
Ansys EmployeeHi As per policy, Ansys Employees are not allowed to download pictures. Can you insert the image of the same.
It is possible depending on what kind of corrugation you are modelling. If the corrugations are tiny (relative to the flow passage), then modelling it as a rough wall works. I would recommend you try validating your work with a similar cases before actual works.
June 30, 2022 at 9:37 pm
eduardo.delarocha
May 11, 2022 at 4:11 pmRob
Forum ModeratorThe other option is to look at the augmentation factor for the wall: https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v221/en/flu_ug/flu_ug_sec_bc_wall.html
June 30, 2022 at 9:38 pm
eduardo.delarocha
SubscriberHi Robert,
Thank you very much for your answer, I will look at it.
Best regards.
Viewing 2 reply threads- The topic ‘Sand-grain Roughness model to simulate corrugated pipe walls.’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- air flow in and out of computer case
- affinity not set
Top Contributors-
3872
1414
1241
1118
1015
