April 28, 2022 at 6:19 pm
hwmachine
SubscriberWhile I was using the Workbench, I found a problem that has never occurred before: "Unable to view geometry, Unable to get model". This is the 1st time I met this problem, the screenshot is sent as an attachment for your reference.
This problem occurs in "Steady Structural" but the "Steady-State Thermal" can run normally.
Thanks in advance!
April 28, 2022 at 6:30 pmMay 12, 2022 at 8:00 amtdevlieger
SubscriberI get a similar error:
System.InvalidOperationException: Unable to view geometry. Unable to get model.
at Ansys.Addins.Infrastructure.Remoting.RemotingApiHelper.FatalApiMethodInvalidOperationException(String message, RemotingApiMethod callback)
at Ansys.Simulation.Core.Commands.EditModel.ViewModel(IFullContext context, DataContainerReference modelContainer)
at Ansys.Simulation.Core.Commands.EditModel.ExecuteCommand(IFullContext context)
at Ansys.Addins.Infrastructure.CommandUtilities.CommandHelper.Execute(IFullContext context)
at Ansys.Core.Commands.Concurrency.CommandWorkUnit.executeInContext(CommandContext subContext, IExecutionEngineCallback tracer)
at Ansys.Core.Commands.Concurrency.BaseWorkUnit.doExecute(IExecutionEngineCallback executionEngine, CommandContext subContext)
at Ansys.Core.Commands.Concurrency.BaseWorkUnit.Execute(IExecutionEngineCallback executionEngine, Boolean dontCatchExceptions)
--- Ansys.Core.Commands.CommandFailedException: Unable to view geometry. Unable to get model.
CommandName: Mechanical.EditModel(Container="Model")
at Ansys.Core.Commands.CommandAsyncResult.RethrowFailureException(Exception e)
at Ansys.Core.Commands.CommandAsyncResult.Wait(Int32 milliSecondsTimeout, Boolean exitContext)
at Ansys.Simulation.Core.Commands.EditModel.InvokeAndWait(IProtectedContext context, DataContainerReference Container, Boolean Interactive, Boolean Hidden, Boolean StartAsReadOnly)
at Ansys.Simulation.GUI.EditModel.InvokeCommand(GuiOperationContext context, DataContainerReference dcr)
at Ansys.Simulation.GUI.EditModelBase.InvokeEditModelOperation(GuiOperationContext context, IGuiOperation guiOperation, DataContainerReference dcr)
at Ansys.UI.GuiOperationContext.Invoke(GuiOperationMetaData operationData)
at Ansys.UI.UIManager.InvokeOperationCore(String pseudoname, OperationDelegate callback, Boolean allowOSMessages, Boolean coreTransaction, Boolean deferredRefreshOnly)
If you can help me out, that would be great.
Sincerely
November 11, 2022 at 9:31 amHarish B
SubscriberI'm also facing the same issue. It would be great if someone helps me.
January 26, 2023 at 2:10 pmpdlagrosas
Subscribersame problem here
Viewing 4 reply threads- The topic ‘How to deal with “Unable to view geometry, Unable to get model”’ is closed to new replies.
5094
1831
1387
1248
