April 24, 2022 at 7:40 pm
Jee Loong Hee
SubscriberDear ANSYS,
I found the icons or fonts on the drop down tree of the Workbench to be extremely small, could you advise me when will ANSYS developer improve this? And is this matter currently being look after by the team?
Thank you.
Yours Sincerely,
Jee Loong
April 26, 2022 at 12:43 pmGeorge Karnos
Ansys EmployeeThere is discussion, but nothing to report yet.
You can try these workarounds to help with the Display of ANSYS Programs:
Automatic scaling and graphics window interactivity may not work correctly for 4K monitors by default.
You can set the QT_AUTO_SCREEN_SCALE_FACTOR System Environment Variable equal to 0 to restore auto-scaling and graphics window functionality
Please try the Windows System Variable listed above and let me know if this resolves the problem.
ALSO:
1.Change the High DPI settings under compatibility settings. " Properties of workbench > Compatibility > Click on Override high DPI scaling "
2. Change the "Scaling performed by" option to "System(Enhanced)"
Viewing 1 reply thread- The topic ‘When Will ANSYS Workbench Be Scaled to Support 4K Monitors?’ is closed to new replies.
3572
1193
1076
1063
952
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
