April 15, 2022 at 12:51 pmsirusblack07Subscriber
I would like to extract the mass property values using scripting in SpaceClaim for a specfic body selection.
Thanks,
April 19, 2022 at 12:12 pmAniketForum ModeratorWhich of the mass properties are you looking for?
-Aniket
April 19, 2022 at 2:03 pmErik KostsonAnsys EmployeeTo get volume of a part on the tree see this:
volume = GetRootPart().Bodies[0].Shape.Volume
Also the MeasureHelper functionality can help with that.
selection = BodySelection.Create(GetRootPart().Bodies[0])
volProps = MeasureHelper.MeasureVolume(selection)
To get mass with MeasureHelper one needs to assign density (properties) to the part in question.
Then one can use the MeasureHelper GetMassProperties method to get the information.
All this can be recorded via the UI and them the above calls will be visible.
Search the forum and the internet to see how to record SC scripts.
All the best
Erik
May 19, 2022 at 12:33 pmFirasBejarSubscriberThank you that solved my issue
RegardsViewing 3 reply threads- The topic ‘How to extract volume properties using scripting in SpaceClaim?’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- Unable to attach geometry 2024 R2
- Getting Mesh Faces With Specified Normal Via SpaceClaim Scripting (V241)
- How to provide blade angles in bladegen.
- DXF file loaded incorrectly
- plugin error failed to import assembly from spaceclaim
- Overlapping contact face
- Thermoelectric Cooler Model
- Issue Seeing Explore
- Warning Plugin Error Geometry in Design Modeler
- SpaceClaim stops sharing topology
Top Contributors-
1406
599
591
555
366
