April 8, 2022 at 8:47 am
Zhang_Z_P
SubscriberDear Friends,
I want to divide a pipe into 3 sections with 2 section planes,and only display the middle section. But it always displays two sections of them. What should I do to solve it?
Thanks a lot.
April 8, 2022 at 9:29 amAkshay Maniyar
You can select which side of section plane should be visible. Click on section plane 1, and then click on edit section plane option. Now, you can click on line (dotted or full line) to make that side visible. So, by properly selecting the side for both section plane you can make middle portion visible.
Thanks
Amaniyar
April 8, 2022 at 10:01 amApril 8, 2022 at 10:05 amZhang_Z_P
Subscriberby the way, Can you see the 2nd picture?@ Amaniyar
April 8, 2022 at 10:19 amApril 8, 2022 at 10:36 amZhang_Z_P
SubscriberMaybe I should set the language to English.
April 8, 2022 at 2:04 pmApril 8, 2022 at 2:44 pmZhang_Z_P
SubscriberHello, I found a strange phenomenon just now. When I click the "solution", it did display the middle portion, but when I cilcked one of strain contours, it showed the whole pipe again´╝ü
Now I inferring that the two parts on each section plane's visable side are simply overlapped, but not performed ÔÇÿ&ÔÇÖ´╝êAND´╝ë operation.
Do you know how to fix it?
Thanks Zhang
April 8, 2022 at 4:14 pmAkshay Maniyar
Section planes behave differently for geometry and results. Please check the Ansys help link for more details.When viewing a result or a mesh, the cut is performed by a software algorithm. When viewing geometry, the cut is performed using a hardware clipping method. This hardware clipping cuts away the model in a subtractive method. The software algorithm cuts away the model but always starts with the whole model. Because of this, it is not taking effect of 2 section plane while viewing results.
The workaround which I can think of is to cut the pipe in 3 parts in SpaceClaim and use share topology. So that, you can extract results for middle portion as a separate part.
Thanks Amaniyar
April 9, 2022 at 3:02 amZhang_Z_P
SubscriberThat sounds not easy,,I'll try it later.
Thanks for your patience again.
Best wishse Zhang
Viewing 9 reply threads- The topic ‘problem about section planes’ is closed to new replies.
6289
