0 is not a valid type ID number. Type ID number must be a positive integer. Error on command
    • ragnhildurkristinsd
      Im getting a error when using the Drucker-prager in command snippet in ansys. I don't know if the error is in the commands or in the model. The model is attached in wbpz file and the cad file in .sat . I also put a drive link in.
    • dinhan0394
      The command object in Geometry is suppressed ->Unsuppress and re-solve again
      Hi thanks for a quick response. I had the command under the material tree. like you can see on the photo below
      When I run the simulation like on the picture above I get a convergence issue. I suppressed a large part of the model but still get a convergence issue. I was wondering if the model is too big for a student licence?
  • The topic ‘0 is not a valid type ID number. Type ID number must be a positive integer. Error on command’ is closed to new replies.
