April 2, 2022 at 3:52 pm
pedro_phcr
SubscriberI'm trying to run a 2-way FSI with RSM in an ARC cluster in the SC GUI(since I have to use quasi-newton method) but I can't configure the machines and methods. I have done the configuration of the cluster and the queue in "RSM Configuration" and tested it without problem, however I cannot configure the machines and cores in the "Parallel solve setup" window in SC GUI. The machines are not shown there.
April 25, 2022 at 3:55 pmStephen Orlando
Ansys EmployeeIs ARC a job scheduler? If so it is not supported. If not, which job scheduler is being used?
April 25, 2022 at 5:17 pmpedro_phcr
SubscriberDear Steve Thank you for your reply. I believe ARC is the job scheduler. Is there a way to find it out?
If that is the case, what would be an alternative? Install SLURM on the cluster and integrate with ansys? Is there any instruction on how to do that?
Viewing 2 reply threads- The topic ‘2 way FSI in System Coupling GUI RSM – machines’ is closed to new replies.
3597
1243
1092
1068
953
