April 1, 2022 at 10:11 am
ollie_boulton
SubscriberI'm running a Coupled Field Transient model of FSW process. I then run the output file on a cloud server. When inputting the .esav file back into workbench i get the below errors. Can someone help.
I also did a bench mark and run the simulation on my computer which worked fine but when running the same model on cloud i get the same error. All units seem to be the same even in the APDL file. Ive also overrided the units in Analysis Data management to MKS.
Im running it on cloud as the model currently takes over 12hrs on my machine and renders is useless for other work.
April 11, 2022 at 5:16 pmAshish Khemka
Ansys employees cannot download the attachments. The unit system message looks like a warning. Can you please share the snapshot from the solver output?
Regards Ashish Khemka
Viewing 1 reply thread- The topic ‘FSW Analysis Error with units’ is closed to new replies.
5799
1305
