Is UDF working properly or not
    • Chinchedu
      Hi, I'm using Ansys Student Version 2021 R2 and installed visual studio 2017 community, set the environment variables. I have written UDF for my problem and able to build and load successfully. But after running simulation I'm getting the same result with and without UDF. How to check whether my UDF is working properly or not.
      Did you hook it up?
    • Chinchedu
      Yes I did. I'm working on two phase evaporation/condensation model. I have written UDF for mass and energy source terms. And hooked mass source terms in respective phases and energy source term in mixture phase under cell zone conditions.
    • DrAmine
      Add a couple of User Defined Cell memories to keep track of the returns.
      Why aren't you working with multiphase dedicated mass transfer UDFs?
  • The topic ‘Is UDF working properly or not’ is closed to new replies.
