The solver engine was unable to converge on a solution for the nonlinear problem, please help
    • MohammedMeqdadi
      I am using ANSYS 2021/R2 Student edition to simulate RC beam and received the following error message
      The solver engine was unable to converge on a solution for the nonlinear problem as constrained. Please see the Troubleshooting section of the Help System for more information.
      How I can solve this error
      Thank you
    • Saumadeep Choudhury
    • ErKo
      Hi Also the below shows a recommended way of simulating RC structure (slide 10 shows for the Menetrey-Willam model a setting to help with convergence):
      Thank you
      Erik
    • MohammedMeqdadi
      I use the Menetrey-Wiliam model a setting but new error coming
      An unknown error occurred during solution.Check the Solver Output on the Solution Information object for possible causes.
      I use in Solve Process Settings Number of utilized cores 2 and on the Home tab, I untick the 'distributed' option
      but still there is error as per the attached picture
      Please help to solve the problem
      Thank you
      Mohammed Meqdadi
  • The topic ‘The solver engine was unable to converge on a solution for the nonlinear problem, please help’ is closed to new replies.
