TAGGED: 3d-geomertry, geometry, geometry-editor, spaceclaim
February 19, 2022 at 3:39 am
m_youssef91
SubscriberCan I edit a sketch in the Spaceclaim after converting it to solid? If yes, could you please tell me how?
February 19, 2022 at 1:45 pmpeteroznewman
SubscriberThere is no sketch after it becomes a solid. You can pull the face of the solid to change the shape using the Pull tool.
February 20, 2022 at 10:21 pmm_youssef91
SubscriberSo if I want to change a radius or any dimension on the model I should redraw it from the beginning?
February 20, 2022 at 10:51 pmpeteroznewman
SubscriberIn SpaceClaim, on the Design tab, there is a button on the ribbon called Pull. Click that (or type P on the keyboard), then click on the cylindrical face. An arrow and a dimension will pop-up. Drag on the arrow or type in a new value for the dimension.
February 20, 2022 at 11:29 pmm_youssef91
SubscriberThank you very much, I did it
August 8, 2023 at 7:10 pmGerald Fly
I am new to Spaceclaim and I have entered a sketch of a rectangle. I want to change the size of the rectangle. This is trivial in Solidworks or NX but I can't access the dimensions of the sketch after I first enter it. I have created the rectangle but didn't hit the space bar to actually enter the dimensions. How can I edit the dimensions?
Viewing 5 reply threads- The topic ‘Editing a sketch’ is closed to new replies.
3817
1388
1188
1100
1015
