February 8, 2022 at 11:48 am
djnckln
SubscriberHi all,
I need help regarding an error that I am getting when using Mechanical. I was using Ansys 18.1 and have been updated to 2021 R2. I am running the same simulation for testing purposes. I was able to run in 18.1 but now I get the following error.
"An error occurred while starting the solver module. Please refer to the Troubleshooting section in the Ansys Mechanical User Guide for more information"
I cannot find anything helpful in the user guide that may help with this. In the solve process settings I have unchecked "distribute solution". I am sure that it isn't my model as I have ran this on another machine without issues and had no issues when running 18.1.
Does anyone have any suggestions.
Please help.
February 9, 2022 at 6:53 amVinayak Vipradas
This error can occur if the Project is saved to a network drive or OneDrive folder.
Save the project to a local folder i.e C:\test and see if the solver runs properly.
Please refer to the following discussions, which might be helpful:
An error occurred inside the SOLVER module: general error (Reccurent problem) ÔÇö Ansys Learning Forum
An error occurred inside the solver module: General error ÔÇö Ansys Learning Forum
Regards Vinayak
How to access the ANSYS Online Help ÔÇö Ansys Learning Forum
Rules & Guidelines ÔÇö Ansys Learning Forum
February 9, 2022 at 12:24 pmdjnckln
Thank you for your message and for your help.
I have tried your suggestion but I get the error " An unknown error occurred during solution. Check solver Output on the Solution Information object for possible causes."
I am undertaking modal analysis on a simple geometry.
When I evaluate results, I get the following errors:
"The result file C:\Users\MSI-USER\Desktop\Ansys\Tube with parameters_files\dp0\SYS\MECH\file.rst cannot be opened."
"Current result file may not contain requested result data C:\Users\MSI-USER\Desktop\Ansys\Tube with parameters_files\dp0\SYS\MECH\file.rst. Please clear the solution and solve again."
"An error occurred when the post processor attempted to load a specific result. Please review all messages."
Thank you for your help.
Viewing 2 reply threads- The topic ‘Error when running simulation in Mechanical’ is closed to new replies.
