January 27, 2022 at 2:00 pm
Ngang
SubscriberJanuary 27, 2022 at 2:05 pmNgang
SubscriberJanuary 27, 2022 at 2:08 pmpeteroznewman
SubscriberDon't look at the last Unconverged substep. Look at the second last row in the tabular output which is a converged substep.
Look at the Solution Output to find out what caused the solution to stop.
Please use the Windows Snipping Tool to capture a screen image. Don't upload phone images.
January 27, 2022 at 2:10 pmNgang
SubscriberOkay
January 27, 2022 at 3:33 pmJanuary 27, 2022 at 4:28 pmpeteroznewman
SubscriberI gave you the rigid dynamics model in December.
What do you need from the Transient Structural that you aren't getting from the Rigid Dynamics model?
January 29, 2022 at 6:34 pmNgang
SubscriberI need to add a periodic explosive pressure of about 300bars applied to each wing just at the moment the wing closes up with the chassis and this pressure has to gradually decrease as the wings open up indicating the expansion of the gas. From there, I wish to get the resultant torque at the rotor shaft considering the shaft rotates at 6000rpm and when it rotates at say 60rpm.
Otherwise I wish to find the reaction force exerted at each revolute joint between the wings and the rotor cylinder, considering the rotor shaft rotates at 6000rpm with a torque of 130Nm.
January 29, 2022 at 6:49 pmpeteroznewman
SubscriberEverything you described are pressures or forces being applied to parts. Can't you do that in Rigid Dynamics?
The only reason you would need Transient Structural is if you needed the parts to be flexible.
March 14, 2022 at 6:00 pmRameez_ul_Haq
Subscriber,I want to observe the connections that you have built in this Rigid Dynamics model. Is it possible for you to upload the archieve file for this project for ANSYS 2021R1 version please?
March 14, 2022 at 8:51 pmpeteroznewman
SubscriberThe archive is in my post in this discussion: /forum/discussion/34814/assistance-with-connections-remote-points-and-displacement-of-a-rotary-engine-design
March 15, 2022 at 6:34 pmRameez_ul_Haq
Subscriber,yes sir I know you have already uploaded it, and I cannot open that archieve file since it is saved through a later version of ANSYS than the version that I am using.
I don't know it is possible within ANSYS to save files at a previous version or not. If it is, then I would be grateful if you could re-share the same archieve file but for the version 2021R1, since this is the one I currently have.
March 15, 2022 at 8:55 pmpeteroznewman
SubscriberUnfortunately, there is no way to save as a previous version.
Viewing 11 reply threads- The topic ‘Transient Simulation of an engine design’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
Top Contributors-
3907
1414
1256
1118
1015
