January 22, 2022 at 4:48 pm
WolfgangNeil
SubscriberCan someone guide me to understand how to retrieve the surface equation from 3D response charts? -
January 24, 2022 at 4:10 pm
Ashish Khemka
Which product are you using the optimization for - Mechanical, CFD, or any other product? Please comment.
Regards Ashish Khemka
January 25, 2022 at 2:15 pm
WolfgangNeil
I'm using optimization under DesignXplorer for a simulation with Mechanical.
Regards
January 27, 2022 at 9:40 pm
Sheldon Imaoka
Exporting the equation is possible if you have set "Response Surface Type = Standard Response Surface - Full 2nd Order Polynomials". If you generate a response surface under this condition, when you go to "Goodness of Fit", right-click on the output parameter in the Table to select "Generate Advanced Goodness of Fit Report".
The transformation information and quadratic surface terms will appear. Please refer to the DesignXplorer documentation (online help) for more details on the "Advanced Goodness of Fit Report".
(The equations will change for a different output parameter, so that is why it's per output parameter, not a single equation for the entire response surface.)
Regards Sheldon
January 28, 2022 at 2:58 pm
WolfgangNeil
SubscriberThank you for your inputs
Viewing 4 reply threads
- The topic ‘Response surface’ is closed to new replies.
1312
