January 13, 2022 at 5:18 pm
daniel9th
SubscriberI'm trying to skin/loft my airfoils (varying scale/chord and twist) to generate a turbine blade but I keep on getting this error. Can someone point out my mistake or potential workaround?
Error Message: Skin Feature Cannot Produce Valid Geometry
Context: Geometry Engine, while generating Feature Skin?
January 14, 2022 at 9:36 amKeyur Kanade
Ansys EmployeeEvery curve should have same number of vertices. Please check it.
Make sure you create it between only 2 curves. If it is successful, you can edit it to add one more and so on.
Please go through help manual for more details
Regards Keyur
January 14, 2022 at 9:37 amKeyur Kanade
Ansys EmployeeYou can also check SpaceCLaim. Please check Blend or Pull commands in SpaceCLaiim.
Regards Keyur
January 17, 2022 at 6:56 amdaniel9th
SubscriberI only used 1 airfoil (NACA 63-815) and only manipulated its chord through scale and twist through rotation. It should have the same vertices right? I tried lofting it with only two airfoils hoping that it was the complexity of having multiple twists that made the error. Unfortunately, no luck. even with only two airfoils (63 815 with different chord length and twist) it won't loft.
January 17, 2022 at 11:12 amKeyur Kanade
Ansys EmployeeCan you please check SpaceCLaim?
If you still want to do it in DM, I suggest you to try first on one simple case and make sure that inputs to skin/loft are correct.
Skin/Loft (ansys.com)
Regards Keyur
Viewing 4 reply threads- The topic ‘Skin/Loft Problem in DesignModeler’ is closed to new replies.
5159
1836
1387
1249
