Preprocessing
Preprocessing
The usefulness of “capture curviture”
    • maxning
      I have a wing surface within a fluid regime that I need to mesh for analyzing its moment coefficient in a flow. It is in the shape of this:
    • Keyur Kanade
      Yes, for wing, you will need to capture curvature correctly.
      Please check following videos
      Ansys Meshing Sizing:
      https://www.youtube.com/watch?v=w4q6q8nKF3U
      Please go through help manual for more details
      Regards Keyur
    • maxning
      But I have selected "yes" for the "capture curviture" setting in the main "mesh" tab, it is just the face sizing tab--right click "mesh" --> sizing--> select wing surface--that I didn't select the "capture curviture" though. And if I do select the "capture curivture" in the options for face sizing then it adds so many hours to the meshing process, or it wouldn't even work.
    • Keyur Kanade
      Please check min and max sizing.
      Please increase min sizing.
      Regards Keyur
  • The topic ‘The usefulness of “capture curviture”’ is closed to new replies.
