December 26, 2021 at 1:36 am
Dave123
SubscriberHello,
I use ANSYS Additive to export build processor files for simulations.
When I import EOS machine build files, I get this error:
Input file(s) was not loaded sucessfully. OpenJZ: EOS_ERR_NO_ERROR, Congifuration: EOS_ERR_FILESYSTEM_IO_ERROR
Any idea what would be the cause?
Thanks.
December 28, 2021 at 10:08 pmJohn Doyle
Ansys EmployeeOne possible explanation might be (...from the Known Issues and Limitations Section of Additive User's Guide (R2022-R2 beta)): "When attempting to import an older EOS build file, the Additive application may reject it since version 2.8 of the EOS API is stricter in regards to the OpenJob format. If this happens, you will see an error under the import availability status like this: Input file(s) was not loaded successfully. OpenJz: EOS_ERR_OPENJOB_INVALID."
December 30, 2021 at 10:29 pmDave123
SubscriberJohn For build files import, can the Additive applicationread multiple parts ' slices, or it can read only one part?
Thanks.
Viewing 2 reply threads- The topic ‘ANSYS Additive – Build files import ERROR’ is closed to new replies.
3622
1303
1132
1068
1008
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
