All results files in one directory
    • BassaSelim3
      Hello everyone,
      I am working with Ansys workbench mechanical and I am doing a parameter study in a modal analysis:
    • Rahul Kumbhar
      You can set the design point as current and check the errors in Mechanical. You might getting error since the result file is not present in the Workbench's solver directory as you changed the directory.
    • BassaSelim3
      Hi rkumbhar thanks for your answer. I checked the messages in mechanical in an other design point, but I get only this message:
      I think it has something to do with the changed working directory as you mentioned. At first Ansys generates the jobname file:
      A bit after that the jobname and the working directory is changed:
      As a result I get the result- files in my specified directory:
      And in the original working directory for each design point these files:
      Maybe this fact causes the error?
      Do you know how I can handle this problem?
      Regards
      Bassa Selim
  • The topic ‘All results files in one directory’ is closed to new replies.
