December 7, 2021 at 12:40 pm
FaizanYounas
SubscriberHello there,
I'm running the transient simulation for condensation in the microchannel. The simulation is ok and I got the graph for the local heat flux. But, I want to calculate the time-averaged wall heat flux? Honestly, I don't know exactly how to calculate the time-averaged wall heat flux from the local heat flux. Is there any way to do it in post-processing? Or do I have to calculate it separately?
December 7, 2021 at 2:01 pmDrAmine
Ansys EmployeeIf you have already your run finished and you have report file for local heat flux: just use third party program or python to do the averaging over time. I assume the local heat flux is vs flow time so make the time average out of it using any integration rule.
December 8, 2021 at 2:31 amDecember 8, 2021 at 1:11 pmDrAmine
Ansys EmployeeOkay then you need to create a mean heat flux at each position: you can do that with Fluent Data Sampling. If you do not want to repeat the run: you need to sort it out "outside" of Ansys Fluent.
Viewing 3 reply threads- The topic ‘Time-averaging in fluent’ is closed to new replies.
3492
1057
1051
965
942
