Load with SF command
    • Evgenii_K
      Hello everyone, I want to apply the convection boundary condition via the SF command:
      SF,surface5,conv,20,25
      SF,surface2,conv,20,25
      SF,surface3,conv,20,25
      SF,surface4,conv,20,25
      IC,body1,temp,25
      ALLSEL
    • Evgenii_K
      I'm sorry I figured it out
    • Erik Kostson
      That is great - could you please post your answer here as this issue might happen possible again to someone else, and then they could find an answer to their problem in your post.
      Thank you
      Erik
    • Evgenii_K
      Hi Erik, The mistake was in the Named Selections name.
      I worked on a scenario in which I wanted to implement Goldak's model - this model is used to simulate swaki and as a test problem I decided to implement a simpler one - a Gaussian distribution model in which I made a mistake, the correct scenario looks like this:
      This script is freely available.
      I will return to the GoldakÔÇÖs model later and create a separate topic for discussion, I think there will be many interesting things.
  • The topic ‘Load with SF command’ is closed to new replies.
