TAGGED: error, error-object-f, fluent, meshing, spaceclaim
November 26, 2021 at 2:14 pm
mjmohd
SubscriberGreetings,
I'm getting this error when I import the Geometry from Spaceclaim into Fluent. I managed before to import the same Geometry and do the Simulation but it is not working anymore!
the error I'm getting in Fluent:
C:Usersmajd_DesktopBAAnsysAnsys 8BA_filesdp0FLTGFluent>"C:Program FilesANSYS IncANSYS Studentv212/scdm/SpaceClaim.exe" /headless=true /Splash=False /WELCOME=false /CommandLineAddInsOnly=true /ADDINMANIFESTFILE="C:Program FilesANSYS IncANSYS Studentv212/scdm/ConversionAddInXml.txt" /EXECUTECOMMAND=ConversionAddIn.Convert No mathcing resource could be found for length with Id:
Status1:ConverterInput16379354613496:C:/Users/majd_/Desktop/BA/Ansys/Ansys 8/BA_files/dp0/Geom/DM/Geom.scdoc
11/26/2021 3:01:40 PMError2:ConverterInput16379354613496:C:/Users/majd_/Desktop/BA/Ansys/Ansys 8/BA_files/dp0/Geom/DM/Geom.scdoc
Error: FMD conversion of "C:/Users/majd_/Desktop/BA/Ansys/Ansys 8/BA_files/dp0/Geom/DM/Geom.scdoc" has failed!
Error Object: #f
December 1, 2021 at 2:44 pmVigneswaran Sridharan
Ansys EmployeeHi Please check if It works with the conversion .scdoc -> .fmd in SpaceClaim and then import the fmd file in Fluent.
If it works, I suspect the anti-virus blocking some functionality inside Fluent for the conversion.
Vigneswaran
December 1, 2021 at 4:52 pmDecember 1, 2021 at 5:22 pmmjmohd
Subscriberso I think it is a problem with the versions Ansys 2020 vs.2021!
I tried to do my simulation using Workbench 2020 and it worked.
I had even different supported types in SpaceClaim 2020 in comparison to the newer version 2021!
do you know why this is happening?
I tried to reinstall the latest version of Ansys again but the problems are still there!
Viewing 3 reply threads- The topic ‘Error while importing Geometry file from SpaceClaim into Fluent with meshing’ is closed to new replies.
6625
1311
